Typhoon won´t start!
powercat6
Re: Typhoon won´t start!
hey dudes good news my ty run! :)
Bad news my ty runs rough! :-(
any thing i can do?
Congratulations. What ended up being the issue?
Now that you have it running use datamaster with the engine running and post the file,
3rd_amigo
i have disconected the brown cable on the passenger side! and he runs!
i make in a half hour a a datamaster file and post it here ok!?
AND THANKS FOR THE HELP!!!!!
IM VERY HAPPY AND ALL THE GUyS THAT HELP ARE GOOD PEOPLES!!!!!
3rd_amigo
hey dudes i have see dtc error in the datamaster file
code 42 for etc?
is this the prob why my ty is runing rough?
BG Domi
powercat6
i have brown wire connected!
or is this saved in my ecm and i reset the code!?
You may have to reset the code. Does the truck start and idle fine after connecting the wire?
If the truck is running good and "check engine" light is still on you will need to clear the code manually.
The code can be cleared manually by disconnecting your battery for one minute and then reconnecting the battery.
The_Bronze
Disclaimer! I downloaded Datamaster tonight for the first time. Since I am unfamiliar with the set-up, please feel free to critique. :tup:
Your first run. A start up from nearly cold (or it's hotter there than I want to experience).
Vehicle is at idle, with a low vacuum of only 15". This should be closer to 18" or a bit higher. After 50 seconds, your vehicle goes into closed loop and the PCM immediately starts to remove a large amount of fuel. The O2 sensor may not be warmed up at this point, but if it is, The O2 should be reading at least 800mV since it is the computer thinks it very rich (due to the rapid short term fuel decrease). I am NOT saying it's rich or lean at this point, only that the data says so. IAC count too high (see note at bottom).
Your second run. The engine temperature is nearly the same, so you have likely just left it running and ran another record (I haven't looked into how long you can record, but I am assuming it's longer than 1 minute).
You are having periods of misfire as your crosscounts run up to 10/sec. You should only be getting a few a second. Even with a fast O2 sensor, 5 at higher RPM is usually typical. This doesn't happen very often though, so overall, you are not in a misfire. At the 85 second mark, your vehicle starts to add fuel (O2 reads lean). After the 90 second mark, the O2 sensor never sees much over 300mV again (lean indicated) After your throttle "blips" at the 112 mark, the vehicle is adding a bunch of fuel, the O2 sensor says lean and your vacuum rises over an inch at idle and hangs kinda steady. At the end of the run, the vehicle is still adding a large amount of fuel, the O2 sensor still indicates lean and when this vehicle quickly decided it was lean, the critical inputs to the PCM (load, rpm, coolant, tps) didn't change, outside of a gradual increase in engine temp. Something external (or a bad O2 sensor/wiring) is changing.
Next issue, IAC counts at 70 when the vehicle is mostly warmed up is way too high, on my scanners, it is around 15 warm, steady idle. I say the idle is being forced open to make up for another problem- such as cam or spark timing, a very dirty throttle body or plugged exhaust. Even when the vacuum rises back up closer to normal, the IAC counts stay high. Judging some of the posts, it looks like setting the timing got it running, but was it done correctly?
Another issue. Block learn monitoring does not look like it is enabled, since it shows the same value from the cold start. I would think that it would be disabled until closed loop is achieved and there is no code set. CLEAR THE CODE.
What I would do Install a fuel pressure gauge. Yes, you already checked it but we need a dynamic, real time value as things start to change. For example: Car starts running rich and fuel pressure stays the same?
Next- start the vehicle cold and run it until it reaches it's normal operating temperature. You can record this cold start as well, but it's not the one I am concerned with.
Next, ensure the O2 sensor is warmed up by a running the engine at 2500 rpm or so for a few minutes.
Then watch and record fuel pressure while performing another logged run. If you can give me a few solid minutes of idle, some WOT on the brake (engine in gear) for 10 seconds or so and then some more idle, it would be easier to make a diagnostic decision.
Alright guys, let me have it! :)
The_Bronze
So after a bit of sleep, IAC counts should be about 15 for DSMs. Around 30 is closer to normal GM I believe.
3rd_amigo
ok i will do a new datamaster scan when he have the operating temperatur,
some minutes of idle some with wot !
but thanks
powercat6
A lot of the people who have Datamaster will be at work for a few more hours. What is the engine doing?
Does it have a rough idle ?
Does it stall or die ?
What type of spark plugs are in the engine (Manufacturer ? Part number ? Type ? Gap ?)
If the plugs have Platinum electrodes replace with plugs that have a Copper electrode. These engines run poorly with Platinum plugs.
Some Compatible Spark Plugs:
AC Delco: CR42TS
NGK: UR5
3rd_amigo
i have cr42ts from ac delco.
when i start the truck he runs not idle and when I press the gas, will not accelerate the vehicle!!!!!
AC Delco: CR42TS
NGK: UR5
The_Bronze
Like the last trace:
Engine vacuum low and unsteady / Idle air control IAC counts are much too high. Engine has to add more bypass air to keep it running than it should / Assuming the DM data and the O2 sensor is okay, the engine is running very lean. On the last run it never once crossed over 450mV, even with the vehicle adding a crapload of injector on-time.
Going back to basics, and with only a half hour lunch and no desire to reread the whole post again, Have you disconnected your EGR valve? An open EGR valve will drop your vacuum, create the rough/no idle and fuel issues, but it won't keep it from running at higher rpms and load. Verify EGR is disabled and not not getting pushed open by high backpressure, weak spring or such. It definitely isn't going to cure your whole range of issues, but it's a good place to start. Maybe make sure your vacuum line to the EGR goes through the EGR solenoid and isn't connected to manifold vacuum or such.
I know you had a fuel pressure gauge on it. But I don't see where you indicated fuel pressure this last time around like I suggested. It's important. Plus, it would be helpful to know if you add extra fuel if the O2 sensor responds with a higher voltage (over 800). (I would add propane and watch the 4 gas. Over 1% CO will make your O2 sensor run 800mV+. Replace O2 or fix as necessary).
A good vacuum reading would also be handy. The gauge is cheap and easy to install. :tup: The problem with scan data on such a quick cycling PID is that it doesn't really show much. A mechanical vacuum gauge reading and how it's reacting will tell a bunch. Such as a steady low vacuum can be timing, A sharply bouncing vacuum reading is a mechanical (not fuel or ignition) problem such as loose adjusters, blown headgasket and such. A vacuum reading that drops lower as you increase the load can indicate restricted exhaust. The vacuum reading will give us a better idea which direction you need to go.
So without looking back at the posts yet:
Vacuum gauge at idle and then when you apply a load.
Fuel pressure readings during your DM run. Note when fuel pressure changes and by how much.
Verify back pressure. I use an adapter connected to the same vacuum/pressure gauge you will be buying at sears. A couple PSI at load is way too much. I screw it into the O2 sensor hole, run the hose up to the car and drive it into the parking lot. I then send a bunch of people to get their GM cats replaced under extended warranty. Time: 5 minutes.
You don't have crosscounts. Assuming the O2 sensor is working (you replaced it), If you were having a ignition related misfire, you would be seeing 10-30 crosscounts (voltage swings rich/lean during a second). This does not happen on a good running vehicle, but if you misfire, the fuel WILL show up as rich/lean transistions (at the 10-30mS transition speed around idle) if it is. Crosscounts are WAY easier than hooking up a scope!
Do these. You have 120 posts on this topic trying to figure out a basic no start/crappy run. I haven't even hit 50 posts yet!
My no start: Spark? Fuel pressure correct? Injector pulse? Speed of cranking? Compression?
My run rough: Fuel trim numbers. Vacuum (can't tune up a 5 cylinder SyTy ;) ) Crosscounts, and then it varies. Ignition scope/just drop cylinders one at a time with a test light though the distributor cap (boots pulled off or back unless they are crap and will be replaced anyways) Injector balance test, compression. You just need to give us the above items. If it won't run over 3K rpms, you have a issue.
That's my 10 minute asessment. Other guys doing this longer may be able to get you there without that, but I would be guessing.
