Typhoon won´t start!
powercat6
Re: Typhoon won´t start!
OK just checking.
After cranking the engine (trying to start) check to see if there is petrol on the sparkplugs.
You have checked everything else. Could be an ECM failure...not firing the injectors.
Can you try a different ECM?
On page 4 he mentioned that he had fuel on his plugs. :tup:
3rd_amigo
ok i dont have any ecm to test. this is the prob and a new one cost 300euros=390$
and 20 days shipping.
hmmmm
djwaggoner
Oops! TNX Powercat...missed that.
ECM's sell for $100 on here.
I have one that you can use to test, & if that's your problem $100 & it's yours..........
LMK
powercat6
LMK
DJ, If he's getting fuel on his plugs, then isn't the ECM working properly? If the ECM is bad how are the injectors spraying? I always thought the ECM managed electronic injection.
WyoSyclone
Do you have a battery charger so you can charge the battery and make sure it stays high during cranking? You said it was dropping to 8 or 9 volts during cranking.
djwaggoner
True, Powercat.............(rats!)
So what else could fail within 6 hrs while the truck was sitting ? It was running & then it won't start...if the batt was too low, it wouldn't crank like we see/hear in the video.
If _nothing_ was changed..............
3rd_amigo
I Buy à Gelbattery in the Next days! And thats Not the alternator? Some german wont to Start when He is Bad! But i don't no how is that on tys!
Thanks for helping dudes
My 79 Monte Carlo is Not so difficult like the Ty! :) hehe
3rd_amigo
i had buy a optima red top battery and had build in my ty
but he wont start!
hmm i dont know whats the problem!
3rd_amigo
hey dudes and can the EST Electronic spark timing/ or the esc are te problem?
but where is the est or the esc!?!?!?!?!
domi
powercat6
I don't think the ESC knock sensor would cause this problem, but the EST Distributor may be off from base timing. Have you rechecked base engine timing with a timing light? Base timing is supposed to be seat at 0 degrees Top Dead Center for Cylinder number 1.
Cylinder arrangement:
6 5
4 3
2 1
Radiator
Front of truck
Better diagram here:
Firewall
Zero degree timing mark is the right notch in the metal shown in a photo in post # 15 this thread:
http://www.syty.net/forums/showthread.php?t=73347&highlight=timing
It's possible that the timing chain jumped ahead by a gear tooth like previously mentioned and now the injector spray and spark plug firing are not timed correctly.
If anyone on here sees any errors in my post please correct or clarify as necessary. :tup:
3rd_amigo
ok i buy tommorow a timing light and check this! but how i can setting the timing?
WyoSyclone
Domi, when you changed plug wires maybe you changed the position by one space. Take number one spark plug out and bring engine to top dead center on #1 (look at harmonic balancer to see if timing mark is close). Take off distributor cap and see where rotor is pointing. Is rotor pointing to connector on distributor cap that is connected to #1 plug wire? If not, then change so that #1 wire matches, then switch other wires to correct position.
Domi.... going through this routine will get you close since the truck won't start.
1madgumby
It is on the left notch not the right.
6 5
4 3
2 1
Radiator
Front of truck
Firewall
1madgumby
Unplug the brown single wire under the passanger side carpet, mark the LEFT notch on the balancer, hook your light up, . Have someone turn the truck over & check to see if the light is flashing on the mark. If not turn the Dist. until the light is flashing on the mark. Might start of be prepared. Hope this helps.
