3rd_amigo
Re: Typhoon won´t start!
the balancer outer ring!? where is this ring????
BG Domi
BG Domi
Yes, it has happened to me.
I thought the exact same thing when I started reading this post. Try disconnecting the vacuum hose to the EGR valve and see if it closes (or the diaphragm moves if you are not sure which way is closed)
Second with regard to spark plugs, I assume you have taken them all out to check for spark. I fell foul once and was checking for spark just using the HT lead to ground with a spare spark plug. I found the plugs badly fuel fouled and they wouldn't spark. replaced them and Bingo!
Also check all the engine grounds are OK rear of drivers side cylinder head and front of intake manifold.
Another check is the temperature sensor by the thermostat housing. if this is bad, can cause starting problems, especially when cold. Try removing sensor plug, and also shorting across it to start, then remove or it will be too rich when warm.
Have you timed the engine? the balancer outer ring may have walked. mine has! Check firing order is correct.
Dont give up! probably something simple.
