Ultimate with PTE
SeattleSy#1255
Category 5 Conservative
Was talking with Zav this weekend and he thought you could use the stock boost selonoid and ultimate with a PTE kit...I was under the impression that you couldn't do this and was going to use a boost valve for boost control, removing the chip from the boost control loop yet maintaining the ability to use the chip for timing advancment.
Am i understanding this correctly, or it is possible and recommended to do it using the chip as the boost control source?
Zav will owe me a burger if he'swrong! :D
turbodig
Re: Ultimate with PTE
Tell Zav to warm up the grill.... you can do it.
Gotta re-program the Ultimate to do it, but it's certainly doable. I've got
a PTE-44 Ty here that runs solenoid control.
As far as recomended...you'll get varying opinions. Personally, I think
it's kind of a waste to have the positions in the chip and not use them.
Later,
Dig
HighPerformanceTrucks
Lift & Shift Specialist
Later,
Dig
I'm using the Btsc Boost Command, but it sure would be nice to be able to use the boost control from the Ultimate.
Adam
ZavzTy547
Senior Member
Dig,
So your saying it can be done corrrect?
Curious, why would you have to reprogram the chip to make it work, since the PTE setup uses internal wastegate?
I'm planning on getting a PTE kit over the winter and want to use the ultimate to run it ..
Also, when are you comming to Washington? Jeff is considered our master tuner and now everyone is running on 5 cylinders, so we need your help... :D
smeagol
ZavzTy547 said:
Dig,
It can be done, no problem. The stock chip/ecm/solenoid can control an external gate if you want even.
The problem is really in the calibration. The boost control is not just a simple desired value in the chip tables. There is a control algorithm, and some tables. IMO, the algorithm is not good... but can work. Also, the stock, or stock type, calibrations are not good for a PTE setup, as the PTE setup has a higher pressure actuator, so it has a higher base boost than stock.
It is akin to asking why you need to change your chip calibration for larger injectors, when you are still running gasoline...
If anyone has some tuning hardware/skills and would like some help in getting control of a PTE system... let me know. I'd love to be able to offer a decent PTE boost control calibration in my chips.
turbodig
ZavzTy547 said:
Dig,
We could start a club on the 5 cyl thing... it seems to be going around.
The reason for the reprogram is that the mechanical behavior of the
PTE gate is waaaay different from the on the the Mitsi. An external
gate is different from either of them... you pretty much have to tune
a chip to the WG config that you have.
The Garrett WG likes things to be real slow. You can darn near get by
with having the WGDC be flat all the way across, but you'll have to do
some tweaking in places to keep it from spiking at highway speed.
It also acts like it would like a second boost solenoid in there in parallel
with the first. The extra bleed volume would let it hit higher boost levels
without cranking the spring pressure up so much. Makes it less likely
to bind.
As for my travel plans, I dunno. I'd like to get back up there, but it was
a lot easier when the company was paying for my plane ticket. I think
my wife's got relatives up there, so it might be easier to go if I can use
the "visit the family" thing. ;)
You can always get on the custom chip program... then I don't have to
be there. I've even got a 4-1 keyswitch setup, for the guys who don't
need all the positions.
Later,
Dig
