ZavzTy547 said:
Dig,
So your saying it can be done corrrect?
Curious, why would you have to reprogram the chip to make it work, since the PTE setup uses internal wastegate?
I'm planning on getting a PTE kit over the winter and want to use the ultimate to run it ..
Also, when are you comming to Washington? Jeff is considered our master tuner and now everyone is running on 5 cylinders, so we need your help...
We could start a club on the 5 cyl thing... it seems to be going around.
The reason for the reprogram is that the mechanical behavior of the
PTE gate is waaaay different from the on the the Mitsi. An external
gate is different from either of them... you pretty much have to tune
a chip to the WG config that you have.
The Garrett WG likes things to be real slow. You can darn near get by
with having the WGDC be flat all the way across, but you'll have to do
some tweaking in places to keep it from spiking at highway speed.
It also acts like it would like a second boost solenoid in there in parallel
with the first. The extra bleed volume would let it hit higher boost levels
without cranking the spring pressure up so much. Makes it less likely
to bind.
As for my travel plans, I dunno. I'd like to get back up there, but it was
a lot easier when the company was paying for my plane ticket. I think
my wife's got relatives up there, so it might be easier to go if I can use
the "visit the family" thing.
You can always get on the custom chip program... then I don't have to
be there. I've even got a 4-1 keyswitch setup, for the guys who don't
need all the positions.
Later,
Dig
