Typhoon-Dennis
I need a new TC...i have a nearly stock engine and will also bye a new Turbo maybe a TD06 20G...
So what a TC would be nice?a 2400Stall TC?
Hi folks,
Is TCS the name brand?
I run a 20G w/ a 10 cm/2 housing. Spooling is a little slower than I would like, but would prefer something around 2500 r.p.m. I don't think I need as much as 2800 r.p.m.
So, what are my options? Jerk? TCS? Coan? There is at least one other name that I cannot recall right now.
Best,
Ranger
Aiken, SC
Yank. Just as a note I d get like a $300 one until ur over 450 ft lbs. Unless your trying to protect some investment in a tranny.
Contact Rusty in AZ, he will get you what you want. http://www.tcsperformance.com/contact
I ran a 20G w/a 10CM housing for a while & it spooled almost as fast as a stock turbo.
You need to have a great flowing exhaust & intake system to have the turbo spool up quick.
What exhaust set-up & intake set-up are you using?
Thanks; I will contact Rusty but was looking for a lower cost alternative than the pricey converters. A rebuilt converter for a 91-92 Corvette or, better, the L35 Blazers, should go for about $150.00.
I run a gutted cat with a Borla muffler w/ stock-looking dual tailpipes. Only intake mod is a K&N filter stuck on the end of the stock intake tube, so flow should be "pretty good."
Best,
Ranger
Aiken, SC
You don't want a 91/92 corvette converter, it's about 250 rpm tighter. I would leave the stock converter in for your mods, swapping TC is a lot of work for little gain if any.
Best,
Ranger
Aiken, SC
