yet another failed emissions thread
sy#2921
BAMF
Re: yet another failed emissions thread
sorry i typed it wrong but meant that the exit was hotter than the inlet temps like a good cat should be
BillC
What chip are you running?
If you can burn chips (or know someone who can), you could always do an "emissions" chip to get you through testing. Lean it out (reduces HC) and reduce the timing (reduces NOx).
sy#2921
BAMF
right now is a custom burn from turbo dig all i know is it is calibrated for the 50#'ers and the 3bar map and suppose to be conservative. I really only need to reduce the fuel at an idle since they dont even check the nox literally no reading comes out only n/a in both fields. I think i have narrowed the problem down to a leaky/faulty injector or just a rich tune.
QUICK STORM
B.A.M.F. BMW Tech
that will do it. if you can list your gas readings and i'll see if i can help.
HC=unburned fuel
CO=partial burned fuel(also can indicate rich/lean)
CO2=indicates how efficient the cat is
02=outside air influence
NOx=oxides of nitrogen(no measured in a 2speed idle test for AWD)
sy#2921
BAMF
first test:
470 standard is 220
.4 standard 1.2
12.7 n/a standard
no o2 on the sheet at all
nox was n/a and n/a
second test after tune up of msd cap and rotor, delco cr43ts (only for emissions), delco o2 sensor, ignition module, msd coil
365 standard is 220
.1 standard 1.2
14.3 n/a standard
nox was n/a and n/a
third test after putting on msd 6a box and lowering fuel pressure from 46# to 36# point where it barely runs
335 standard is 220
.1 standard 1.2
14.1 n/a standard
nox was n/a and n/a
all tests were done with 93 octane and a bottle of heet to 8 gallons of gas
QUICK STORM
B.A.M.F. BMW Tech
i would bump fuel pressure up a bit as you see it really didn't change your hc. you don't want to get to low and get lean misfires. check those injectors.
turbodig
What's the label on your chip say... I may have something that'll work better.
later,
sy#2921
BAMF
its says ,kris 50#, if you want i can read whats on the chip into a binary file and send that to you or just send you a list of mods, i will be getting my datamaster cable soon so i might be able to get some logs as well
turbodig
Ah, that'd explain it.
If that's the same one I'm thinking of, it's a delta off what BG did with the truck, which was
open loop all the time. Probably pretty rich.
If you have a burner, I'll send ya a file to try. Send me a PM.
later,
Dig
QUICK STORM
B.A.M.F. BMW Tech
later,
Dig
there you go, no fuel control.
smeagol
later,
Dig
Sounds like that's the case. The truck passed with flying colors when I had a closed loop chip in there. I just liked the idle & drivability of the open loop cal.
Course that was with a fresh ignition, decent gas, and a newer cat. Best to have the truck pretty warm too.
sy#2921
BAMF
Well the truck now has a completely new iginition system gas is good and the cat is fine. There has been a small hiccup at an idle ever since i got the truck and isnt as bad now that i did the tune up but maybe that is the open loop talking. Truck idles at 900 rpm then ever once in a while it studders down to like 700 just for a second then is rock soild at 900 again. The place told me that this truck passed in 02 sometime and was almost half of the standard so it was making me mad i was double
