aldl interface without 12 volts.
canadian
sy in progress
has anybody come across any sort of aldl interface hardware that doesn't require 12v to run it? i've seen all the schematics on the net and a large number of different hardware pieces, but they all require some sort of 12v source to power them.
does anybody know of a "passive" aldl stream converter that doesn't require power? i'm guessing the chips need 12v to run properly?
odium
1BADGMC
I have an ALDL cable that doesn't use a 12v source (cigarette lighter, etc.) I have no idea who made it or how though; I got it used...
BigBadSmoosh
you could use the usb port to power the circuit..
Im not sure how the circuit to do the conversion will actually get its power if you don't have a 12v source..
I guess you could use a battery or something.
canadian
sy in progress
diacom cables don't have an external power supply (believe they get it from the parallel port). i'm looking for something to run off a serial port, but without the current draw on a battery powered computer and something a little neater than having some huge mess of wires hanging out of the cigarette lighter (or whatever source).
if it's not possible, i'll look at the 12v power from the truck. just wondering if it was possible to do it without needing a 12v source (maybe 9 volt battery)?
hmmmm:
http://cgi.ebay.com/ebaymotors/ws/e...tem=7923691515&category=33598&sspagename=WDVW
This cable supports 160 & 8192 bps ECM data streaming.
No external power source required !!! ( powered from PC/Laptop RS232 port).
Our cable have built-in 10K resistor required by MAF systems and some ECMs.
It simple to change a mode of work with this option - instruction come with a cable.
notice how they say that datamaster supports the syty (which is true), but not whether their cable will communicate with the 7749. wonder if any of the ecm gurus can chime in here.
BigBadSmoosh
SyTyArchives said:
Im pretty sure all the chips needed to convert the data over to serial need power.
most likely +/- 5v..
so technically they could grab it from the parallel port, I think the serial port also have a 5v output..
so i guess it is possible..
InvisiBill
I did some research on this when I made my cables (http://cable.invisibill.net/). If I remember correctly, not all serial ports will provide power properly using the methods described. Neither parallel or serial have a direct +5V. USB does, but the data capturing stuff seems to be flaky on USB.
I plan to hardwire the cable into my truck. I'll get data and ground at the diagnostic plug, and run one wire over to the fusebox for 12V.
Hmmm, if I can get my laptop to hold a charge for a bit, I'll see how well it works with TechEdge's power-via-serial method (linked from my page).
PPI Typhoon
DIY Madman
I just bought my parts for making a few cables last night. It's using the Maxim MAX232 chip. It also uses a 5V regulator to use power out of the serial port. I think if you don't use the regulator, it could be problematic. The schematics I'm using are here (actually Bill, I got this from one of your earlier posts):
http://www.home.aone.net.au/techedge/vehicle/8192schm.gif
The MAX232 seems to be a pretty common IC used in active serial port interfaces. I should be assembling it this week. I'll post my results.
Anyone know where to source a molded ALDL connector?? If not, I'm also thinking of permanently mounting the adapter in the truck with just a serial port in the glove box.
BTW: Parts for 3 cables (minus the serial cable and project box) was $20.24 at a local shop. Pretty cheap.
turbodig
Re: aldl interface without 12 volts.
I've never externally powered any data cables, either DM or Diacom.
The DM cable has a plug only for the few laptops that may be out there
that can't drive the handshake lines well enough to provide ~100 mA
of current.
If you really wanna, use a 9v battery as was suggested above... I guess
I wouldn't bother.
Diacom does simliar things... uses the printer handshake lines to drive
signals Hi/low. It has an advantage of not having to convert from RS232
signaling levels to TTL. (Like all the serial cables do)
I made my own cable with a MAX 232 years ago when the chips first
started becoming available. Have yet to find a laptop that won't power
it sufficiently, but I also use 2 lines (through a diode) to power the cable.
Plenty of current capability.
Later,
Dig
turbodig
I didn't use the regulator, I don't think.. mine worked. There are versions
of the MAX23x line that will accept higher voltage on VCC. I'll have to
look at my old cable. I built it for a VB app I was writing years ago.
That schematic looks pretty close to the same thing I have wired up.
Pretty much the app note from MAXIM, with the power supply part added.
One thing - gotta make sure the S/W you use is setting both those lines
to +12. If it's only one, it likely won't have enough drive.
Dig
turbodig
Dig
turbodig
canadian said:
did you ever get it working?
Sorta.
About the time I started working on the UI heavily, DataMaster came out.
Wasn't much sense in re-inventing the wheel.
I had a few PC's where I couldn't get it to link... timing specifics.
I started on some rolling-timing link code, but I never pursued it further.
I always wanted to implement mode 4, so we could command the ECM
to do things. Not much utility, but kind of neat, nonetheless.
Later,
Dig
InvisiBill
I just modded my cable for this the other day. I simply ran a diode from each pin to where my power wire connected to the resistor. No regulator or anything (since it was running off direct +12V before). Works great on my Compaq LTE5280 (P120, 32MB). My only problem was that on my cable (the prototype), I didn't hook up the "ALDL" ground to the circuit, only the lighter plug ground, so I had to fix that too in order to completely bypass the lighter plug.
If anyone else wants to mod a cable from me for this, I used 2.5A, 1000V diodes from Radio Shack (276-1114, it's a pack of 3), which are the same rating as what I used in the cable's circuit. Just scrape off the liquid electrical tape where orange wire goes into the resistor, and solder the striped end of the diodes there, and the other ends to pins 4 and 7 (nothing else in those pins). I was able to put them fairly close to the other stuff, so it all still fits inside the shell just fine.
